90mm Throttle Body?
Old Jan 10, 2006 | 09:36 AM
BuffC5's Avatar
BuffC5
Default 90mm Throttle Body?
I was poking around online, and I found this 90mm TB. Anyone have it? Looks great. CNC too.
http://dezod.com/pd_comtech_performance_90mm.cfm
Old Jan 10, 2006 | 09:40 AM
mdhmi's Avatar
mdhmi
$500 duckets for a TB? Looks purdy, but I'd lean towards the LS2 90mm TB for $200.
Mark
Old Jan 10, 2006 | 10:25 AM
WKMCD's Avatar
WKMCD
Mark
My LS2 Tb works great even before it was ported. Price was very right.
Old Jan 10, 2006 | 11:28 AM
BuffC5's Avatar
BuffC5
Mark
Yeah price is a bit steep, but to be full CNC Billet Aluminum AND 90mm.....HIGHLY considering it.
Old Jan 10, 2006 | 11:34 AM
99 vett babycar's Avatar
99 vett babycar
If you're going to put a 90mm TB in and spend that kind of money you should only consider the best - Nick Williams - no tuning problems , codes, etc.
Old Jan 10, 2006 | 11:42 AM
dfe1's Avatar
dfe1
The LS2 throttle body control motor isn't compatible with the LS1 system. How did you hook it up? By the way, I've had one of these ComTech throttle bodies for over a year, and I can tell you it's a kick-*** piece. I don't know about any of the other brands but it has performed flawlessly.
Old Jan 10, 2006 | 12:03 PM
BuffC5's Avatar
BuffC5
I thought the motor on the TB was a different connection, operated on the other side and a different way......
Thanks for the feedback.
Any codes or re-tuning needed? Was it really Plug N Play?
Old Jan 10, 2006 | 12:28 PM
ChipN's Avatar
ChipN
I ran across this one (link below) from LG Motorsports. Looks nice and doesn't require any additional porting (per LGM). Costs more than the LS2 TB but once you factor in the cost to hand port the stock TB it is probably a wash. Given that I personally would take something like this for consistency.
http://www.lgmotorsports.com/catalog...oducts_id=1110
Old Jan 10, 2006 | 12:55 PM
Phil97SVT's Avatar
Phil97SVT
I've got a couple NW90mm TB's I need to get rid of and will help with the tuning. I like the fact that the NW90mm needs no porting and opens in the same direction as the standard LS1 style TB.
Phil
Old Jan 10, 2006 | 12:56 PM
WKMCD's Avatar
WKMCD
The motor is fully compatible with the C5. There are PNP harnesses from vendors - I forget where I got mine. Installed the FAST LSX and LS2 Tb and drove away. The car idled fine even with my cam. PHIL97SVT ported the intake and Tb when he installed the new heads. Everyone has reported the LS2 Tb is very easy to tune.
Old Jan 10, 2006 | 01:07 PM
see5's Avatar
see5
The LS2 TB works like a top, it is the FAST intake that is challenging.
Old Jan 10, 2006 | 03:42 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Katech plug-n-play harness adaptor, is about $50.
Old Jan 10, 2006 | 09:04 PM
turboc5's Avatar
turboc5
Does the ls2 tb bolt up to a fast 90mm intake. Don't the ls1 and ls2 tb's have a diffrent bolt pattern. And PHIL97SVT what do you mean by diffrent direction. Does the blade open in the oppisit direction? Does it affect airflow negitvly?
Old Jan 10, 2006 | 09:22 PM
JoeyG's Avatar
JoeyG
LS1 and LS2 throttle bodies open up 180 degrees from each other. The LS2 throttle body bolts right up to the fast 90
Old Jan 10, 2006 | 09:38 PM
smask04c5's Avatar
smask04c5
NW 90 opens in from the top, similar to LS1
Old Jan 11, 2006 | 05:20 PM
wavrdr's Avatar
wavrdr
Phil
Phil, How much do you want for them?
PM me if you don't want it publicized...
Alan
To 90mm Throttle Body?
