BatteryMider Plus Hook Up / Chassis Ground
In connecting this in the car (as opposed to taking the battery out of the car), the instructions give you two options, depending on which post/cable of the battery (+ or -) currently in the car is grounded to the chassis of the car. I can't difinively determine if it's the negative from just looking at it, but in looking through my car manual, I believe it is (based upon the jump start instructions). Can someone confirm that I'm correct that it's the negative cable that's grounded to the chassis? Thanks!
Last edited by Dr. Solo; Jan 10, 2006 at 05:07 PM. Reason: Clarification of statement
Fred
Thanks. The inst. say to hook the non-grounded to the battery cable (in this case, the pos.), and the neg. clip connection from the BatteryMinder goes to the vehicle chassis or engine block. Thanks again for the confirmation!
