Kumho Ecsta Spt Ku31??
Any buzz on these tires? I found a source online which is selling them for <$397plus shipping for all four. They're classed as W-rated Ultra-high performance summer tires 320wear.
Regards,
Garibaldi
http://www.tirerack.com/tires/tires....odel=ECSTA+SPT
reviews
http://www.tirerack.com/survey/Surve...ommentStatus=P
reviews
I'm thinking $400 cannot be a bad thing. I won't list the website until I get some indication that they're legit.
Thanks,
Garibaldi
Regards,
Garibaldi
Tire Rack has these for $102 & $122 each. $450 per set Wow !!!
Everything I've read from Kumho site and the Internet Searches I've done says they are the next gen to the Kuhmo 712's. Kumho says they offer better dry and wet grip, as well as lower noise then the 712's. They also have some kind of wear indicator so the consumer can keep an eye on even wear.
If you go to the Kuhmo site and check the tire grid for this tire it puts them between the MX (Max) and the 712's/ASX (UHP) models.
So Im have to assume they are better performance (grip) then the 712's and ASX, but maybe give up some ground to the MX for better wet traction and lower noise.
The 712's was a very successful tire for them, and everything I've read suggest they performed great but were loud.
Maybe Luke @Tire Rack should get involved here.
The other Tire I'm considering is the Firestone Wide Ovals which a lot of C5 guys are raving about. They say the FSWO are rebadged Bridgestone 750's
Metric 30/35/40/45/50/55 Series, V & W Rated
A unidirectional UHP tire that provides new tire performance in wet and dry even after the tire is more than half worn. It delivers world class technology by combining grip, handling, comfort, exceptional wear and eye appealing characteristics.
UTQG: 320 AA/A
Click Here For Specification Data.
Special Features:
High dispersion silica expands compound performance envelope for superior wet grip and better treadwear.
Race proven carcass design with jointless cap plies, wide steel belts, ESCOT carcass profile and high durometer apex delivers razor sharp response and extreme grip without compromising ride quality.
Three-dimensional lateral grooves optimize water evacuation in footprint.
Triple tread radius optimizes footprint shape for even pressure distribution.
Shoulder blocks tilted into direction of travel to improve grip and reduce worn noise.
Rim Protector in the lower sidewall safeguards wheel against scratches and abrasions.
Typical Vehicle Match:
Porsche Carrera
Corvette
BMW 330i
Nissan 350z
Ford Cobra SVT
Pontiac Trans Am
Subaru WRX Sti
Mazda RX-8
Comparable Competitor Products:
Michelin Pilot Sport
Bridgestone RE750
Eagle F1 GS
BFGoodrich KDW
Yokohama Advan AD07
Pirelli P-0 Nero
Dunlop SP8000
Can you give us a little more input, i.e. How do they compare to the OEM tires in cornering wet & dry grip. Are they as wide as they oem's.
Do you have any pics of them on your C5 that you could post
Actually, the FS Wide Ovals use the carcass of the Bridgestone S02's. My best friend is an engineer and test driver for BS/FS.
