a4 z06?
Jan 12, 2006 | 03:32 AM
a4 z06?
did they make a4 c5-z06's????
Jan 12, 2006 | 03:37 AM
Quote:
I'm pretty sure you couldn't get a Z06 with an A4. I'm almost positive that all you can get is a M6.
Jan 12, 2006 | 03:59 AM
well i said that u couldnt get an a4 in one and one of my "camaro buddies" thought otherwise.
Jan 12, 2006 | 07:24 AM
St. Jude Donor '11-'25
M12 Only
The 01-04 Z06 was available with a M12 trans only. It was geared differently from the M6.
The 06 Z06 is also only available in a 6 spd configuration.
Any Auto you might see was a conversion (like the Z06 convertibles).
Bob K.
Jan 12, 2006 | 09:40 AM
No...if you want an A4 in a Z06, you need to swap out the 6-speed.
Jan 12, 2006 | 11:10 AM
Same is true of the 99-00 FRC's, all M6's.
Mark
Jan 12, 2006 | 05:15 PM
St. Jude Donor '05
Jan 12, 2006 | 08:32 PM
Quote:
Originally Posted by WALLstAL
Looks like a hard top for a vert to me. Close, but not the real deal. The seam is a dead giveaway, as is the way the glass doesn't run all the way down.
Sorny
Jan 12, 2006 | 09:01 PM
Quote:
Sorny
Busted!
Jan 12, 2006 | 09:37 PM
Mine might have one in the spring too. The A4 swap is expensive, but pretty much required for the drag strip.
Mark
