'97-'00 v.s.'01-'04 Headers. What's the Diff?
Old Jan 12, 2006 | 05:29 PM
Too Slow '90's Avatar
Too Slow '90
Default '97-'00 v.s.'01-'04 Headers. What's the Diff?
What is the difference in headers between a '97- '00 and '01-'04. In other words which do you need for a '98 with an '02 LS6? Thanks.
Old Jan 12, 2006 | 06:22 PM
LoneStarFRC's Avatar
LoneStarFRC
Best I can tell, the location of the A.I.R. check valve fitting is on different tubes. This would mean that the steel pipe that goes down to the pass. side header from the A.I.R. check valve behind the manifold may have to be shorter/longer. I don't see what would prevent you from using the steel pipe from a later model as it would reach. Not positive, but the A.I.R. fitting on the driver's side may be in the same location. As I said, not sure on that one though.
Anyone else help him here?
Old Jan 12, 2006 | 06:45 PM
97C5ENVY's Avatar
97C5ENVY
Yep, it's the pass-side A.I.R tube length that makes them different. All else is the same.
Old Jan 12, 2006 | 06:52 PM
dpd's Avatar
dpd
secondary air[a.i.r.]and the oil dipstick tube bracket.97-to at least 01 have it mounted to the header tube,02-04 on the side of the right head
Old Jan 12, 2006 | 07:02 PM
C5COM67's Avatar
C5COM67
I put '99 Dynatech LTs on my 04 C5. AIR tube is the only difference. Requires removal of the intake manifold to get to the connection to remove the AIR tube to swap them out. I put an AIR tube from a 98 on mine, and have the 04 AIR tube in my garage, shipping and it is yours. No problems, no codes. My tube would let you put the 02 style on your 98 ( or did I get that backwards )
Old Jan 12, 2006 | 07:06 PM
Too Slow '90
Default Air Tube
Thanks. That is why I asked. I will actually have both tubes but I noticed that the supermaxx set up from '01-'04 is about $300.00 more than the '97-'00. Thanks for the offer though.
To '97-'00 v.s.'01-'04 Headers. What's the Diff?
