A piller
Old Jan 13, 2006 | 03:44 AM
papas97's Avatar
papas97
Default A piller
Can someone tell me how the A piller padding is removed. Mine is cut and would like to replace it.
Old Jan 13, 2006 | 07:21 AM
ROJO99's Avatar
ROJO99
Grab and pull. The piece snaps in.
Old Jan 13, 2006 | 08:46 PM
TEXHAWK0's Avatar
TEXHAWK0
Are you going to buy a new piece, or have the old one recovered?
The part number for the driver's side is 10434739, and cost about $70. Mine got cut while getting a new inspection sticker.
If you go ahead and buy a new one, you can see where the clips are located and know better where to pull to remove the old one.
The molding has a fiberglass backing, and is held in only by clips, but they can be REALLY tight, where you think it will break before it comes out.
When you install the new one, be sure to put some non-hardening body sealer on the clips, so that the holes in the pillar post are sealed. I had a water leak from the factory around one of the holes and it took me a while to track down where it was coming in.
To A piller
