Rear tie rod ends loose!!
Old Jan 13, 2006 | 12:43 PM
Bob25thTA's Avatar
Bob25thTA
Default Rear tie rod ends loose!!
I have my car up on jackstands replacing the rotors with drilled and slotted ones, and noticed play in both rear tierod ends. Anyone else run into this? Its an 03 with 21000 on it, owned it since new.
Old Jan 13, 2006 | 03:48 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Get some Moog from Vette Brakes Products they are better than stock because they have no plastic. They also have grease fittings. If you swap them measure where they are or you will need an alignment.
Old Jan 18, 2006 | 08:06 AM
Shawn MacAnanny's Avatar
Shawn MacAnanny
I had the EXACT same problem and still ran an 11.8@121 with a 2.0 60ft lol. You need to use a torx bit on a ratchet to keep the balljoint from spinning and a box end wrench to tighten the nut down. You will notice also that your car drifts or steers its self from side to side too. I noticed this. Not a hard fix, im sure the nuts are just loose.
To Rear tie rod ends loose!!
