Battery Removal During Winter Storage
Old Jan 13, 2006 | 02:56 PM
SKULLC7's Avatar
SKULLC7
Default Battery Removal During Winter Storage
Will I have issues come spring time if I removed the battery during winter storage?
Old Jan 13, 2006 | 03:06 PM
Pumba's Avatar
Pumba
You will have to unlock your radio
Your PCM will have to relearn the engine's wants.
Why don't you purchase a Battery Tender? If you hook one of these up, the car will be fine when you start it at the end of the storage period.
Old Jan 14, 2006 | 09:07 PM
Bob Chapman's Avatar
Bob Chapman
Pumba is right
Old Jan 14, 2006 | 11:40 PM
joghotrod's Avatar
joghotrod
Old Jan 15, 2006 | 12:11 PM
FKING1's Avatar
FKING1
Get a Battery Tender and forget it!
Fred
Old Jan 15, 2006 | 01:06 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I keep mine on a phase charger we had on our sailboat. It goes thru stages. Bulk, absorption, and maintain. You don't need anything that complex but I use it all year round. Even in the summer if its going to sit a few days it's easy just to clamp it on...........
Old Jan 15, 2006 | 01:39 PM
Oldvetter's Avatar
Oldvetter
WallMart has a Black and Decker battery tender for $17, works great!
Old Jan 15, 2006 | 03:18 PM
DngrZne's Avatar
DngrZne
I would say get a Battery Tender whether the battery is in the car or not. Either way the battery is going to discharge while sitting, so it would be a good idea no matter what.
Chris
Old Jan 15, 2006 | 06:30 PM
Dave1998's Avatar
Dave1998
My battery has been out since end of November as its dead. I expect no problems in spring.
Old Jan 15, 2006 | 07:20 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
I didn't spend the money on a tender,I need that cash for mods! I just disconnected it and left it in the car. When spring came last year and recently we had the 50+ temps outside, I just reconnected and it fired right up. Oh yeah, I didn't have to unlock the radio, just adjust the time.
Old Jan 15, 2006 | 08:18 PM
SpinMonster's Avatar
SpinMonster
Keep the battery in the car and start it every few weeks.
Old Jan 15, 2006 | 08:57 PM
SLPRC5's Avatar
SLPRC5
Old Jan 15, 2006 | 09:01 PM
SLPRC5's Avatar
SLPRC5
MODS won't do any good if you can't starter her Spring (no pun intended) for a battery tender...one thread said Wal*Mart Black and Decker $17.00 can't beat that...IMHO
Old Jan 16, 2006 | 12:06 AM
cadmanjm's Avatar
cadmanjm
Default My friend left his outdoors and covered in winter (Michigan) and in the spring it...
started right up to his surprise. I don't recommend doing that and it was a new vet, but for about $9 you can get a floating battery tender at Harbor Freight. Can't be that mod for the $$
Old Jan 16, 2006 | 11:14 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Fred
I prefer a Deltran Tender +
Old Jan 26, 2006 | 09:02 AM
JRS_MY_C5's Avatar
JRS_MY_C5
Sears buys a Die Hard 1.5 Amp Automatic Battery Charger. They describe it as an automatic charger/maintainer. You can select 6 or 12 volt.
Here's the description
Has anyone used this for their Corvette?
Old Jan 26, 2006 | 09:05 AM
97Black's Avatar
97Black
I have used that one for the last two years with no problems.
Old Jan 26, 2006 | 09:44 AM
mike348's Avatar
mike348
I use Battery Tender Plus .
Old Jan 26, 2006 | 01:26 PM
JRS_MY_C5's Avatar
JRS_MY_C5
Did you get the 6 volt or the 12 volt?
To Battery Removal During Winter Storage
