Oil cooler?
Old Jan 13, 2006 | 03:57 PM
ElanMike's Avatar
ElanMike
Default Oil cooler?
Someone recommended an oil cooler for tracking. Is this a worth while mod? If so, any suggestions?
Old Jan 13, 2006 | 04:06 PM
TmillerC5's Avatar
TmillerC5
St. Jude Donor '08
If you have the jack this is the best way to go.
http://forums.corvetteforum.com/show...68&forum_id=23
I wish I had the money.
Tim
Old Jan 14, 2006 | 01:32 PM
Alex D's Avatar
Alex D
Unless you are regularly exceed 280F oil temp, I wouldn't do it. The greater concern is that the oil stays too cold all the time. Your oil must reach 212F every once in a while to fully burn off contaminants and moisture.
If you run high oil temps all the time I would rather go to a 5W-40 oil than put an oil cooler in.
I really think an oil cooler only makes sense for autocrossers or very high speed driving applications such as on Germany's autobahn.
Old Jan 14, 2006 | 06:45 PM
vette113's Avatar
vette113
Are you saying an oil temperature of 243 degrees at a DE event is okay?
To Oil cooler?
