Another check engine problem
Old Jan 13, 2006 | 06:48 PM
bb609's Avatar
bb609
Default Another check engine problem
'03 Z06 - Cruising up the highway tonight 65-70 and the DIC goes nuts, c/e and traction light on, no acceleration. I limp home and try to pull the codes. Only 3 history codes showing:
P1515 Command vs Actual Throttle Position Performance (PCM Module)
C1278 TCS Temporarily Inhibited By PCM
U1064 Loss of Communications with BCM
Half hour later at home, the car starts and runs fine but c/e light is still on.
Car is basically stock but I installed a new air bridge recently.
Anyone have any thoughts what it might be before I have to call the dealer?
Edit - I stutter a lot too...
