Need Customer Tracking Specs?
Old Jan 13, 2006 | 07:09 PM
ElanMike's Avatar
ElanMike
Default Need Custom Tracking Specs?
When I put on the larger wheels and had the Vette lowered, I had them dial in some customer allignment. I believe the Vette was originally positive camber, but I went with negative camber for better cornering. I just don't remeber how much.
Does anyone have some recommendation I can pass to the shop? They will be re-doing my alignement on Monday after the balancer is repalced and the new tie rods installed.
Old Jan 13, 2006 | 09:48 PM
davidfarmer's Avatar
davidfarmer
this is within OEM specs, but maxed out for handling.
Front
camber -1.05
toe .1 deg in
castor 8.5 deg
rear
camber -.95 deg
toe 0.2deg in
Old Jan 13, 2006 | 09:49 PM
davidfarmer
btw, those are C5 numbers. The new C6 Z06 allows up to -1.6 front and -1.5 rear camber
Old Jan 16, 2006 | 06:27 PM
ElanMike's Avatar
ElanMike
This is a C5.
The castor seems quite high. 8.5 is correct?
To Need Customer Tracking Specs?
