Code question on fast 90/NW 90 install?
Old Jan 14, 2006 | 04:33 PM
smask04c5's Avatar
smask04c5
Default Code question on fast 90/NW 90 install?
I just installed a fast/NW 90 on my car in sig. Started car and it idled down as before. Took it out and drove it for about 10 miles and twice it has gone into power reduction mode and on the dic says service active handling. I had my crane handheld with me and cleared twice the same code 0068. Question is, what is this code? I have yet to reinstall the passenger side valve cover vent, just have hose to atmosphere. Could this be the cause? Fabbing a carbon fiber bridge and did not want to poke a hole in the stocker if I could avoid it. Thank you in advance
Old Jan 14, 2006 | 05:09 PM
Phil97SVT's Avatar
Phil97SVT
You need to have your tuner modify the P1514 table. Its a very easy and straight forward ECU modification.
Phil
Old Jan 15, 2006 | 07:30 AM
smask04c5's Avatar
smask04c5
Could I trouble someone to explain the p1514 table?
Old Jan 15, 2006 | 01:41 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
http://www.corvettedoctor.com/2004_DTC_Codes_Page2.html
Old Jan 15, 2006 | 03:05 PM
SpinMonster's Avatar
SpinMonster
You have an air leak.
Old Jan 15, 2006 | 03:59 PM
smask04c5's Avatar
smask04c5
Spinmonster, an airleak forward of the tb? or should I plumb the v/c vent hose forward of the tb and try it? Thank you for the responses
To Code question on fast 90/NW 90 install?
