Specific C5 problems to look for
Old Jan 15, 2006 | 01:24 AM
DSKRALL's Avatar
DSKRALL
Default Specific C5 problems to look for
I may be in the market for a manual transmission coupe. What problems should I look for that are specific to C5s? Thank you.
Old Jan 15, 2006 | 02:30 AM
dpd's Avatar
dpd
piston slap
oil consumption
abs/ah[check for faults,early cars had issues,from harnesses to ebcm's]
coolant leaks[low coolant level,suspect leaks]
climate control operation
keys/ignition/column locks[wait 10 sec.faults,bla-bla]
rocking seats/memory operation
fuel gauge/sender operation
door control modules
water leaking in[clogged a/c drains/wiper cowl drains,etc]
bcm's[from water leaks,see above]
clutch hydraulics/synchro's/hubs/forks
wheel bearings/speed sensors
leaking seat bladders[not on a z06]
hazard/turn/cruise switches
headlamp motors/gears
steering angle sensors[cars with active handling]
i've probably forgot some,but don't let this let you cringe.these are just some quirks that happen on some cars.not every car suffers from all of these.i wouldn't give my car up on a bet.
check for faults,you don't need anything.the car will do it for you[just a matter of pushing a couple of buttons],it will check all systems[electrical]and will tell you faults,history and current
Old Jan 15, 2006 | 09:34 AM
pski694's Avatar
pski694
Originally Posted by dpd
piston slap
oil consumption
you forgot rear end leaks
battery leaks that destroy wires and computers
welds on exhausts are prone to break
I think that covers most
Old Jan 15, 2006 | 10:12 AM
rws.1's Avatar
rws.1
Read the entire thread at the top of the C5 General Section called
Weights, Measures, Ratios etc....
It is a compendium of knowledge of specs, problems, fixes, etc.
there is also dim electronic A/C display...,
Old Jan 15, 2006 | 12:09 PM
FKING1's Avatar
FKING1
Two things from my C5. Column Lock recall and electrical gremlins, i.e., make sure remote fob actuates door locks, unlock and all memory functions. Also, mine will lose its memory at times for no reason. Never had problems with my 00 M6 as the big list posted above.
Fred
Old Jan 15, 2006 | 12:16 PM
DSKRALL's Avatar
DSKRALL
rws.1
Thank you very much for the reference. I looked for something like that before I wrote my post but I failed to check "Weights, Measures...
David
Old Jan 15, 2006 | 01:04 PM
binkysgarage's Avatar
binkysgarage
WOW that is scarey, not alot to look forward to, but I still wouldn't sell it.
To Specific C5 problems to look for
