Another Tire Pressure System Question
Old Jan 16, 2006 | 05:34 PM
finally01's Avatar
finally01
Default Another Tire Pressure System Question
i've replaced my stock rims with aftermarket Z06 wheels and no sensors. Is there a way to turn off the system. I have an 01 and i've down the search on the forum for this and the only thing I've been able to piece meal is to have a "TECH II"??? not for sure what that is. The system, when i start, says low pressure ...yada yada yada and when I hit reset it goes away...but 15 minutes later it comes back on. Hit reset and go through the whole process again...and again...and again...and again. I know the tires don't have sensors in them so where is it still picking up the signal??? Can it be turned off...easily?
Old Jan 16, 2006 | 06:18 PM
skip89's Avatar
skip89
Tech 2 is a device Chevy dealers have and some tuners. Someone on here can post the procedure I hope. About 10 minute job. I had the function turned on on my Z after I installed sensors. You want to take directions with you to the dealer
