LT Headers and Clutch Replacement
Old Jan 16, 2006 | 10:00 PM
out2run's Avatar
out2run
Default LT Headers and Clutch Replacement
Do Long tube headers installoed on an '03 coupe have to be removed to replace the clutch?
Old Jan 16, 2006 | 10:08 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
the headers themselves could stay, but the xpipe and everything else behind it should be removed
Old Jan 16, 2006 | 10:23 PM
turboc5's Avatar
turboc5
If you remove them it makes it much easier
Old Jan 16, 2006 | 10:28 PM
Tsab's Avatar
Tsab
Yes, you should disconnect them from the heads that way you can move them out of the way and give yourself more room to work. Replacing the clutches on these C-5's are not very easy...good luck.
Old Jan 16, 2006 | 10:32 PM
out2run's Avatar
out2run
But, can it be done without unbolting headers from the head?
Is it easier to just unbolt the headers rather than struggle to get to the clutch?
To LT Headers and Clutch Replacement
