Royal Purple Oil...
Old Jan 16, 2006 | 10:04 PM
SLPRC5's Avatar
SLPRC5
Default Royal Purple Oil...
Well today I changed oil and filter in my '97 C5. (with 57,405 miles)
I'm now using Royal Purple 10w30 synthetic and K&N HP1007 oil filter.
In the past I have used Mobil1 and Castrol synthetic oils.
The reasons I went to it is because it claims a HP and torque gain and oil change intervials are 12K miles. Recommending changing oil filter 3k to 4k and top off with the Royal Purple oil.
So with the use of Royal Purple oil; what can I exspect to see with it's usage?
Rsty
Old Jan 16, 2006 | 10:18 PM
allmee's Avatar
allmee
Keep an eye on the filter. The first ( & last ) K&N filter I used had the housing leaking, very slightly. Oil was blowing back on to various parts. I was getting a burning oil smell.
Old Jan 16, 2006 | 10:41 PM
SLPRC5's Avatar
SLPRC5
Thanks for that tip. I've been using them for awhile now with no problems..but I will keep an eye on it..
Rsty
Old Jan 16, 2006 | 11:41 PM
rhneff's Avatar
rhneff
My 96 LT4 saw a 5hp gain from changing to Royal Purple in engine and diff and Castrol in ZF trans. My 02 Z06 was just changed over to RP in engine, trans and diff - saw a 3hp gain. Actual dyno results, before/after. I'm sold on the stuff!
Old Jan 16, 2006 | 11:44 PM
SynistrC5's Avatar
SynistrC5
I had a K&N oil filter that leaked also.
Old Jan 16, 2006 | 11:52 PM
SLPRC5's Avatar
SLPRC5
Could it be from over tightening due to the nut base on the bottom? I've been using them without leakage.
Old Jan 16, 2006 | 11:53 PM
SLPRC5's Avatar
SLPRC5
This is intersting positive input. My A4 has Redline ATF.
Thanks,
Rsty
Old Jan 16, 2006 | 11:57 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
That is interesting since I use the purple stuff in my engine, trans and differential, plus I added the hood seal should be good for gobs of hp with my blower setup
Old Jan 17, 2006 | 01:19 AM
LS9's Avatar
LS9
I only use that nut to remove them.
Old Jan 17, 2006 | 02:00 AM
SLPRC5's Avatar
SLPRC5
That is a very good idea Thanks
Old Jan 17, 2006 | 02:55 PM
MR1911's Avatar
MR1911
I have never bought the stuff before how much are you folks getting it for ? Over at thunder racing they have a deal for 6 quarts and a K&n filter for 39 bucks or so , hows that sound ?
Old Jan 18, 2006 | 03:40 AM
SLPRC5's Avatar
SLPRC5
that is a real good deal..PepBoys 10w30 is $5.99 a qt X 7 (takes 7 for oil change) and $12.00 for the filter. Do the math.
Old Jan 18, 2006 | 10:16 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Your oil filter should be hand tight only.
Old Jan 18, 2006 | 10:33 AM
Rhode Warrior's Avatar
Rhode Warrior
Couldn't find the Royal Purple ATF, but I have the Royal Purple Max Gear in my diff, and RP oil in the engine. For the trans, I went with the Mobil 1 synthetic.
To Royal Purple Oil...
