Intermittant directionals
Old Jan 17, 2006 | 11:14 PM
goodwood427's Avatar
goodwood427
Default Intermittant directionals
Has anyone ever had a problem with the directional lights sometimes not working? They work normally most of the time, but occassionally they do nothing in either direction. It's a 2001. Any help would be appreciated.
Old Jan 18, 2006 | 07:47 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Fairly common, hazard switch needs replaced. Turn signals are incorporated in this switch..........
Old Jan 18, 2006 | 10:29 AM
professorhp's Avatar
professorhp
Old Jan 18, 2006 | 07:33 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Have the same problem. Part is on the shelf waiting for a nice weather weekend to install.
You can check this by turning your hazards on and off the next time they aren't working. If they start working again when you do this, its the hazard switch for sure.
The hazard relay is actually both turn signal relays in one.
Good luck
Old Jan 18, 2006 | 09:17 PM
NAVY08's Avatar
NAVY08
same thing happened to me, if you hit the hazzards sometimes this gets the turn signals to work a few times, its an ok fix till you get it prelaced, it wasnt much at my local dealer
Old Jan 31, 2006 | 11:13 AM
goodwood427
Thanks to all who replied. I will give it a try and let you know the results.
Old Jan 31, 2006 | 11:40 AM
lt1george's Avatar
lt1george
Default switch
Try some electrical contact spray cleaner in hazard switch. Worked for a friend of mine.Let us know how you make out. Save the Wave. Good Luck.>George
Old Jan 31, 2006 | 09:39 PM
2K2 C5's Avatar
2K2 C5
Intermittant? Yeah, mine come on, then go off, come on, then go off, come on, then go off..........
Old Feb 3, 2006 | 03:30 PM
goodwood427
The next time it failed I immediately flipped the Hazard switch on/off a few times and they started working, so you guys are right on!! I flipped the hazard on and off a few more times and so far they are working fine. Apparently the contacts get a little dirty or corroded. How do you go about getting at the hazard switch to get some contact cleaner in there? Thanks again!!!
Old Feb 3, 2006 | 06:05 PM
Lovin It!!! - C5
Pretty tough to get at. You have to take apart a fair amount of the dash. That's why most folks milk it out as long as possible with the hazard switch before they swap out the relay. Its a sealed unit, so you really can't get any cleaner in it.
HTH
Old Feb 11, 2006 | 11:00 AM
goodwood427
So far since I've exercised the hazard switch it's been working fine. Thanks to all for your input.
To Intermittant directionals
