408 cam question.....
Old Jan 19, 2006 | 03:49 PM
NXTFAZE's Avatar
NXTFAZE
Default 408 cam question.....
hey fellas,
What size cams are you 408 guys running?
I'm running this, but I think I reached it's limit. Comp XER grind 242/248 .608/.612 112 lsa
I don't run my car as a daily driver, but I used to and am not afraid of putting miles on it.
I'm interested in something bigger, but don't want to be stalling at the stop light or surging.
TIA
Old Jan 19, 2006 | 07:28 PM
NXTFAZE's Avatar
NXTFAZE
bump....
anyone?
Old Jan 19, 2006 | 07:44 PM
ecudooberhead's Avatar
ecudooberhead
This probably won't help you too much, but I have a G5X3 cam on my 383 that was just finished last week- it has gotten a bit tamer than it was when I had it with stock displacement. So I imagine you could go a bit bigger w/o much problems.
What kind of power are you making with that 408?
Old Jan 19, 2006 | 07:56 PM
NXTFAZE's Avatar
NXTFAZE
Made 465 rwhp/ 445 tq, but i added a FAST intake, LS2 TB, and Bigger 1 7/8 Kooks, no cats and it made 491.77 rwhp/ 486.68 tq. It made 30 to 40 lbs feet more tq across the board, but I'm just not happy w/ the peak hp numbers....thought it would be atleast 500 rwhp, but I think my cam is holding me back.
Old Jan 19, 2006 | 08:52 PM
NXTFAZE's Avatar
NXTFAZE
ttt
Old Jan 19, 2006 | 08:54 PM
Honez's Avatar
Honez
Magic Stick from Texas Speed
Old Jan 19, 2006 | 08:57 PM
NXTFAZE's Avatar
NXTFAZE
My friend has one in his 402 and made 520 rwhp. Just wondering if anyone is going bigger than that.
Thanx for the input...anyone else?
Old Jan 19, 2006 | 09:52 PM
90droptopp's Avatar
90droptopp
From: Murrieta Ca..... America, fun while it lasted
238/242 xer 113 See sig for numbers with a 4.10 gear to boot. It's not your cam. What heads are you running??
Old Jan 19, 2006 | 11:14 PM
NXTFAZE's Avatar
NXTFAZE
Stage III T.E.A. heads......(my setup is in my sig)
I'm happy w/ the torque, but was hoping to get over 500 rwhp. Just trying to compare my setup.
I don't know what else I could do except an underdrive pulley, but that will get me what? 10 rwhp?
Old Jan 19, 2006 | 11:16 PM
Phil97SVT's Avatar
Phil97SVT
Originally Posted by nextphasemarko
hey fellas,
TIA
If you got someone who knows how to tune get a 254/260 110 + 2
Phil
Old Jan 19, 2006 | 11:21 PM
NXTFAZE's Avatar
NXTFAZE
Phil
I'm very confident in my tuner, but how are the road manners for that cam and how does it do w/ nitrous?
TIA
-Marko
Old Jan 20, 2006 | 12:08 AM
jhong321's Avatar
jhong321
Your cam seems to be a good size but what about your heads? I am running a baby cam in my 402 (226/226 lsa 112 .600 ) with a set of patriot heads and am get 473 rwhp and 489 rwtq. If you go to a bigger cam it won't nesseary help you . You might see better peak HP but will not get you down the track any faster as you would be loosing you low end.
Old Jan 20, 2006 | 12:32 AM
90droptopp's Avatar
90droptopp
I can't see your sig....
Old Jan 20, 2006 | 12:49 AM
NXTFAZE's Avatar
NXTFAZE
Sorry, meant my profile:
Y2K Triple Black Vert M6. Borla,Kooks 1 7/8 ,B&M,Slammed. Z06 sway bars. 408ci Iron block 11.1:1 static compression ratio;Fresh LQ4 block bored .030 over,Eagle 4" crank,Eagle 6.125" rod w/ L19 bolt upgrade,Diamond flat top pistons,Comp OE style lifters,A.R.P. head bolts and main studs,Cometic MLS head gaskets,TEA Stage III cylinder heads,FAST w/ LS2 TB, Comp XER grind 242/248 .608/.612 112 lsa, All Motor.....for now. NX on the way...again
Got your pm. Thanks for the input.....
Old Jan 20, 2006 | 02:12 PM
Boob's Avatar
Boob
I'm running a 240/248 .608 .612 on a 112 in a 383 ls1 w/ patriot heads. I dyno'd 486 rwhp w/ 5* knock retard. Torque was 458. That's with an ls6 intake and stock throttle body and TPIS Headers.
I know theres room for improvement in mine and I'm sure there's still some room in yours. I'm gonna see that 500 rwhp mark w/ this cam. Since you have way more cubic inches, I don't see why you shouldn't either. Good luck.
BTW I have an underdrive pulley and was told that they make about a 1hp difference. I tried to research this but couldn't find anyone w/ dyno proven results.
To 408 cam question.....
