AHS -00 compared to -01 model (wheel speed problem)
Changing tires so the speed difference is 0% between front and rear the active handling system slows down the car (braking) when driving at around 40mph or more
Is it possible to change the pre-programmed 3,67% diff. in the -00 ABS/Active handling computer ? OR if the new improved ABS/Active Handling unit that came -01 would solve the problem
