Is that where you found this info?... I thought that was the answer too, but if you look closer you will see that it is under the AUDI DTC heading and not under C5 Corvette.
I have the manual and i found a b1543 but not P1543
Yea...it's the darndest thing! If you look in the manual for P1545, I believe, you will see that it says something to the effect of...confirm and run checks for P1543, but then you go to turn the page back and find it and it only shows P1539. It goes from P1539 and then jumps to P1545. It mentions P1543 in the text for P1545, but there is nothing on P1543 any where
At least you know your engine is not in imminent danger of blowing up.
