Replacing Clutch Master Cylinder
Old Jan 22, 2006 | 05:42 PM
ESCAPEDGREG's Avatar
ESCAPEDGREG
Default Replacing Clutch Master Cylinder
Hello guys, I am having to replace the clutch master cylinder in my '98 C5. I just installed a SPEC Stage 3 Clutch and GM Slave Cylinder in it about 3000 miles ago. Does anyone have any tips on installing and is there a better type of master that I can buy? Any help would be great. C5's are still kind of new to me. Thanks Greg.....
Old Jan 22, 2006 | 05:48 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
get the z06 master, although all c5's 2001 and newer have this as an upgraded part and when you order a new you will get the later master cyl.
Old Jan 22, 2006 | 09:58 PM
RAFTRACER's Avatar
RAFTRACER
Why are you "having to" replace your master cylinder ?? Low clutch pedal engagement?? The majority of SPEC's that I have installed have immediately had a low engagement hieght. If this is the problem, prepare to have McLoed have wallet-sex with you. It is the only thing that will help. The Mcloed mastercylinder has a 1/16 '" larger bore diameter. This fixed my SPEC issues.
Remove drivers side front rear inner fender liner and that will gain you the easiest access. Have fun
Old Jan 23, 2006 | 02:29 PM
WKMCD's Avatar
WKMCD
I run and LS7 clutch and added the Cartek adjustable master so that I could set the engagement exactly where I wanted to.
Old Jan 23, 2006 | 04:07 PM
IFLUBYU's Avatar
IFLUBYU
Old Jan 23, 2006 | 07:47 PM
ESCAPEDGREG
Hey Raft, no the pedal is fine. My problem is that it is starting to leak into the car. I was swapping interiors and noticed the fluid soaked into the matting on it. Plus have been having to add fluid every once in a while. But thanks for the advise. Thanks Greg....
Old Jan 23, 2006 | 08:21 PM
RAFTRACER's Avatar
RAFTRACER
If there are no problems other than leakage, just replace it with a stock one. Sorry about your carpet. If you are careful when you replace it, you may be lucky and not have to bleed it.
Old Jan 23, 2006 | 11:04 PM
tazinhawaii's Avatar
tazinhawaii
I just did this a couple days ago (installed my McLeod cylinder). My advise is to have plenty of band-aids available for the cuts on your arms. It was easier than I thought to get the old one out. But getting the new in is a little tricky. First trying to get it through the firewall and aligned so it can be twist-locked into place was a pain (probably easier with a 2nd person). And then the worst is trying to get the snap-lock ring back on the clutch pedal (to hold the cylinder shaft on). I did it without disassembling under the dash, but if you have medium sized fingers or bigger, expect it to be a HUGE PITA.
Good Luck,
Derrick
Old Jan 23, 2006 | 11:11 PM
RAFTRACER's Avatar
RAFTRACER
Good Luck,
Derrick
An extra set of eyeballs is very helpful. Additionally stick master-cylinder rod through firewall and attached to clutch pedal BEFORE you attempt to twist into firewall (or at least on the correct side of the pedal )
Old Jan 23, 2006 | 11:38 PM
taaz024's Avatar
taaz024
I disagree. I road race and drag race my 98 with a Spec 3 plus. The adjustable master is nice, but not needed. When my spec was installed I had low engagement. We installed a new master and solved the problem with the pedal height. You can also add a spacer if you want the clutch higher. Save the bucks for now and just do a factory master.
Old Jan 24, 2006 | 07:45 AM
RAFTRACER's Avatar
RAFTRACER
I am only speaking from my experience. I have installed 10-11 of these things. On typical stage 3's I dont seem to have a problem, but the majority of SPEC's that I install are stage 3 hybrids with the lightened aluminum pressure plate and aluminum flywheel. Believe me I would rather not have to spend $300+ dollars on that way overly priced McLeod mastercylinder, but in that aplication it seems to be a neccessity. Beats the hell out of damaged synchros in the T56 and associated repair costs of the transmission. BTW I do a little roadracing too
Old Jan 24, 2006 | 11:28 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Danny, is the spec stg 3 with light flywheel/pp what you're recommending for me? I'm still very undecided after reading some mixed reviews. I'm sure that you guys will get it set up right, I just want the long-term experience to be issue-free.
I don't really get into drag racing much these days, as I plan to replace that with autocross this year. Still, I daily drive my car a lot, and want to know what sort of drivability changes to expect.
Avoiding wallet-sex is always a priority until I finish med school...lol
To Replacing Clutch Master Cylinder
