??? Blackwing sits too high???
Old Jan 22, 2006 | 06:06 PM
silverstreak01's Avatar
silverstreak01
Default ??? Blackwing sits too high???
after I installed the Blackwing using all parts supplied and remounting on same bolts and same holes, it is riding too high and hits the hoodliner. did I miss something here?? anyone else find the same thing?? Thanks for your support.
Old Jan 22, 2006 | 09:58 PM
Joevette99's Avatar
Joevette99
Default SAme Here
I had the same problem. See if the connections at the air filter end, around the MAF, are pushed together properly. I was not able to get them all the way snug and mind sits a little high still though it no longer hits the liner.
Good luck.....
Old Jan 23, 2006 | 11:11 PM
silverstreak01
ttt
Old Jan 24, 2006 | 02:06 AM
EagleFlight's Avatar
EagleFlight
I had heard about this before I installed mine, but had no problems, I made sure everything was fully seated at each point and the air ducting was 100% flat vs a little twisted and higher on one side. I also have the high flow CF air duct, so it does not anchor to the shroud in two places like the stock one does.
Good Luck!
Old Jan 24, 2006 | 12:14 PM
tin's Avatar
tin
I Had The Same Problem But My Fix Was To Take A Dremel
Tool And Grind Down The Inside Of The Plastic That
Connects To The Coupler Because It Didnt Go All The
Way In Once I Grinned It It Pushed All The Way In And Now All Fits Good
Old Jan 24, 2006 | 03:50 PM
edensknight's Avatar
edensknight
Have dremel, will travel!
To ??? Blackwing sits too high???
