They will not work on LS1's 99mm bore. This was the original belief and hope. The stock bore is too small on the LS1. Update: The flow numbers were based off a mildly ported set.
The information came straight from GM. It is as stated, unless they make changes. Going into production now. Information should be hitting the newsstands this week as well.
Piano "Aggressive meaning they're going to be a very reasonable price and thus competitive?"
And then some...
GM PART # 12582714
CATEGORY: Engine Cylinder Head
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $281.79
OUR PRICE: $160.62
DESCRIPTION: HEAD
GM PART # 12582714
GM LIST: $281.79
OUR PRICE: $160.62
DESCRIPTION: HEAD
Brent.
At that price, are they iron or aluminum? I'm assuming aluminum, although experience would say iron. I'm sure that to run an aggressive cam one would need to upgrade the springs. Also, do you know what the chamber size will be? I would think that a sleeved LS1 with larger than 4" bore would work if the bolt pattern matches. Looks like an LS2 in my future even though I've been shying away from it due the the knock sensor incompatability.
So how do we get around the knock sensor issues? I've read they were incompatible, but haven't read about any solutions.
And then some...
GM PART # 12582714
GM LIST: $281.79
OUR PRICE: $160.62
DESCRIPTION: HEAD
