yellow folia-tec paint question
Old Aug 6, 2001 | 08:25 PM
BKVIEW4U's Avatar
BKVIEW4U
Default yellow folia-tec paint question
i want to paint my calipers yellow. does the foilia -tec yellow paint match the millenium yellow on the c5?if not is it close enough ? pics would be cool too . thanks .brad
Old Aug 6, 2001 | 08:34 PM
MelloYellow's Avatar
MelloYellow
Default Re: yellow folia-tec paint question (BKVIEW4U)
It matches like HELL. Don't use it! :mad
If you are into yellow, find a mechanic who can locate high temp aircraft paint and matches to your Mill Yellow. I ended up using Folia Black with Red Pads.
Old Aug 6, 2001 | 10:34 PM
JWSchmidt3's Avatar
JWSchmidt3
I use Sunburst Yellow Rust-oleum. About as close as you're gonna get.
Old Aug 8, 2001 | 12:13 AM
BKVIEW4U's Avatar
BKVIEW4U
Default Re: yellow folia-tec paint question (JWSchmidt3)
JW. thanks dude . your car is awesome. ive seen the pics of your interior too. very very :cool:
Old Aug 8, 2001 | 07:45 AM
BatMobile's Avatar
BatMobile
Tropical Moderator
Cruise-In 1-5 Veteran
St. Jude Donor '03-'04-'10-'11
Foliatec does NOT match...it is much much paler.
I sprayed my calipers with Black VHT...then painted the CORVETTE letters with FoliaTec yellow. The yellow is so insignificant, you can hardly notice the color variation.
Neill
Old Aug 8, 2001 | 08:44 AM
maxrep's Avatar
maxrep
I used the FoilaTech Yellow... and while it is not a perfect match... I am happy with it.
When the car is inside in the garage you can really tell the difference as the Millennium Yellow takes on an orangeish tint, but outside in the daylight the difference is hardly noticeable.
Others told me not to use it, but the kit was given to me free and I really like the hardened, glossy "look" of the foilatech as compared to some of the other paints available.
To yellow folia-tec paint question
