Key Fob programming
Old Jan 25, 2006 | 08:14 PM
Racer1x's Avatar
Racer1x
Default Key Fob programming
My RFA module is refusing to let me into the programming mode. I hold the reset button for 3 seconds and push the option button but nothing happens. The radio is off and the dic is cleared but I can not program it, what gives. Anyone have this happen.
Old Jan 25, 2006 | 08:18 PM
vette747's Avatar
vette747
I had the same problem trying to reprogarm a fob. I replaced the fob and it was ok.
Old Jan 25, 2006 | 08:25 PM
Racer1x's Avatar
Racer1x
I cannot even enter the programming mode, that is the problem I am having.
Old Jan 25, 2006 | 08:35 PM
vette747's Avatar
vette747
Strange. I would disconnect the battery for 10 minutes and retry. Good luck. Any codes in the rfa module ?
Old Jan 25, 2006 | 08:38 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
you are not doing it right. turn your key on but do not start the car. cycle options until the DIC is blank. THEN hold the reset button till FOB training appears press reset once and then it tells you to hold the lock and unlock on the FOB. it will cycle through 3 fobs
Old Jan 25, 2006 | 08:43 PM
Racer1x's Avatar
Racer1x
I had some codes but I didn't write the down, I had a dead battery and I was assuming the codes were from that. I cleared them all and tried it againg with no luck. I wil try disconnecting the battery and see what happens.
Old Jan 25, 2006 | 08:45 PM
Racer1x's Avatar
Racer1x
That is exactly the proceedure I am following.
Old Jan 25, 2006 | 08:46 PM
Markm10431's Avatar
Markm10431
Parrothead
how long are you holding it? the book says three seconds but ti takes longer
Old Jan 25, 2006 | 11:52 PM
C5Denny's Avatar
C5Denny
Navigator
Just did this at the dealer the other day and this is the correct process.
Old Jan 29, 2006 | 11:19 PM
Racer1x's Avatar
Racer1x
Man I'm an idiot I have been trying to program two dead key fobs for a week
All I had to do is buy two new batteries for the fobs and it was fixed.
I just figured both batteries couldn't be dead at the same time (wrong)
Anyway I'm just glad its fixed now. And the battery disconnect worked to let me into the key fob programming mode thanx vette747.
To Key Fob programming
