C5 Window controls
Old Jan 26, 2006 | 09:33 AM
bwmcph's Avatar
bwmcph
3rd Gear
Default C5 Window controls
Does anhyone know if there is a fuse, breaker, etc, that doesn't reside in the right side fuse boxes that affects the passenger side window control? Both windows stopped working, and I found one blown fuse behind the passenger side kick plate. After replacing the fuse, the driver side window started working, but the passenger side still doesn't work. The passenger side door control module was recently replaced because the door lock didn't work, but it may be bad again.
Old Jan 26, 2006 | 01:10 PM
CaptKirk's Avatar
CaptKirk
I don't know if there is a different fuse for the passenger side window, but I do know that the contacts in the motor or one of the relay has a tendency to stick from lack of use. This happened to my 2000 coupe a few times until I have the motor replaced by GM under warranty. The quick, cheap and temporary fix is to slam the passenger door a few times had to see if it is the contacts. Hope this helps.
Drive on!
Old Jan 27, 2006 | 10:47 AM
bwmcph's Avatar
bwmcph
3rd Gear
Thanks, I will try that.
To C5 Window controls
