Interior trim removal
Old Jan 26, 2006 | 04:37 PM
Heretic's Avatar
Heretic
Default Interior trim removal
Does anyone have any tips for removing the kick, side and rear panels? I need to get to the RH body harness in my 99 FRC.
Old Jan 26, 2006 | 06:44 PM
turboc5's Avatar
turboc5
Everything is cliped in. Just pull up on your rocker cover and pull it back when the top unsnaps. The rear panels unclip the upper seatbelt cover and remove the torx bolt to the sail panel. Then just pull on the covers. All cliped in, just make sure you pull them in order. Top first.
