Low Washer Fluid
Old Jan 26, 2006 | 06:08 PM
NSTY C5's Avatar
NSTY C5
Default Low Washer Fluid
I have a 2000 with 21K on it. I started getting a message of Low Washer Fluid.Used the Service Manual and replaced the sensor. Still have the problem. It will go out if I press the reset button, but will come back on when I start the car again. Any help, Thanks
Old Apr 25, 2006 | 07:45 PM
97BlckCpe's Avatar
97BlckCpe
ugh mine just started saying this ... is there anyone out there that knows whats up with this? Is there a sensor problem here if so where is it
go to this thread here is the issue
http://forums.corvetteforum.com/show....php?t=1362662
Old Apr 25, 2006 | 08:49 PM
djengr's Avatar
djengr
Have you tried just taking the switch and forcing the contacts open to see what happens. I am guessing it is a float that has open contacts when fluid is above the float/sensor. This would simulate washer fluid above the switch.
I have never taken mine out, just a WAG.
Old Apr 25, 2006 | 09:52 PM
BrentNY's Avatar
BrentNY
Oh boy this bugged me for a year after I replaced it. Then some good guy on the forum said to turn the sensor 180. I was willing to try anything. It worked for me. Unbelievable.
Old Apr 25, 2006 | 10:29 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
make sure you have washerfluid.
Old Apr 25, 2006 | 10:55 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
turn the sensor in the side of tank see if light goes off?
Old Apr 26, 2006 | 08:56 PM
HollywoodFRC's Avatar
HollywoodFRC
When I bought my '99 FRC, kept getting low washer fluid status. Kept putting in fluid, it'd go away and the alert would come back with little use of the washers over time. Bothered me, couldn't figure out where it was going. Finally found that there was a hairline crack along the molded seam of the washer tank, and washer fluid was leaking out slowly. Repalced the tank, no more problems. The fluid level sensor (white cylindrical object at the back of the washer tank) has a grove on it that is supposed to line up with the small lip on the washer tank sensor hole.
Good luck,
Old Apr 27, 2006 | 10:51 AM
97BlckCpe's Avatar
97BlckCpe
does anyone know how much a fluid sensor cost?
Old Apr 27, 2006 | 01:00 PM
CrazyChris's Avatar
CrazyChris
Just unplug the sensor that goes into the washer tank reservoir. The message will not be displayed anymore.
To Low Washer Fluid
