Please help: transmission Service MN6
I want to change my trans fluid in my '99 MN6.
1. I would love to know how to? Need a fluid pump? Pump till it starts coming out?
2. What type of fluid? Syncromesch?
Thanks so much everyone!
check manual for capacities as I don't recall..I used Amsoil fluid which doesn't require the additive for the rear end
link http://forums.corvetteforum.com/show...uid&forum_id=1
BEST thread EVER http://forums.corvetteforum.com/show...18&postcount=4
The diff needs 75W90 gear oil. It is only available as a synthetic.
you will need to buy 2 qts.... but only need about 1.5 qts,
Pick your preferred Brand. I prefer Shell but used Mobil 1
Others prefer Amsoil, Royal Purple, or Red Line,
Any major Brand 75W90 will be fine,
Quaker, Pennzoil, Valvoline, Kendall, etc
Put the additive in first then fill with the gear oil until it begins to overflow.
Jim M
In answer to a few of your questions,
The fluid is added via a fill plug which is on the driver's side of the diff, about half way forward and halfway up. The temp sensor plugs into the fill plug. Fill until fluid comes out the hole. The drain plug is on the lower rear corner of the passenger side. I suggest you open the fill plug first, because if you open the drain plug first and then have trouble getting the fill plug open, you will be sad...
FYI, AMSOIL Dexron III fluid for the C5/Z06 is product code ATF: AMSOIL ATF. Tranny will take just under 4 quarts. You will need a pump, like the AMSOIL Hand Pump, product code G2039, to pump the fluid up into the fill hole. This pump screws right onto AMSOIL quart bottles. Ordering info in my sig.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
