LS2 Head experts: Please step inside
Old Jan 27, 2006 | 03:07 PM
Casem1's Avatar
Casem1
Default LS2 Head experts: Please step inside
What is the valve stem length on an LS2 head vs. the LS6 head and the LS1 head?
Most specifically: what length pushrod would be required for an LS1 that will be getting LS2 heads and an LS6 camshaft?
Old Jan 27, 2006 | 07:29 PM
Casem1's Avatar
Casem1
ttt c'mon guys!!!
Old Jan 27, 2006 | 09:32 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Your best best is to buy a $20 pushrod checker and check your specific setup to be sure you are using the correct length pushrod.
Old Jan 27, 2006 | 09:35 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Old Jan 27, 2006 | 10:08 PM
Casem1's Avatar
Casem1
Originally Posted by Threed
This site has been too good to let me down low...
Old Jan 27, 2006 | 10:46 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the difference between the 2002-2004 ls6 valve and the 2001 or 2005/6 LS2 valve is .6mm(not a 100% on this), most shops will use the standard 7.4 p/r's w/ the 2002-2004 LS6(lighter, sodium fill valves)for cam swaps
the question comes down to what valve is in the '243' or LS6/2 head, as noted previosly the only valve that will be of different length is the 2002-2004 LS6 valves(this was due to the different base circle used)
243 heads(JUST THE CASTINGS,BARE) are the same from 2001 to present(used in the LS2's)correct??
i also noticed the ls2's use the same yellow spring as the ls6's in the c5's, although they have the smaller lift 2001 cam w/out the reluctor ring, cam positon sensor runs off the cam sprocket up front
To LS2 Head experts: Please step inside
