Rotor nut size
Old Jan 28, 2006 | 04:04 PM
JUSTAKAR's Avatar
JUSTAKAR
Default Rotor nut size
Guys, What size is the Hub nut inside the rotor on a 2002 Z06?
Thx in advance
Old Jan 28, 2006 | 04:29 PM
Lestat52's Avatar
Lestat52
The nut doesnt hold the rotor on. There should be some clips on the wheel studs holding it. If not, once you take the caliper off, the rotor will pull off.
Old Jan 28, 2006 | 04:48 PM
JUSTAKAR's Avatar
JUSTAKAR
Default Thx
Thx for the info I should have asked the size of the hub nut , in the centre of the rotor....1st question changed.
Old Jan 28, 2006 | 04:59 PM
rws.1's Avatar
rws.1
Based on using a digital micrometer it is 33 millimeters.
I know a 34 mm socket is a bit big (sloppy)
Old Jan 28, 2006 | 10:35 PM
JUSTAKAR's Avatar
JUSTAKAR
Default thx
Thx for the info....Ian
To Rotor nut size
