HIGH FLOW CATS..what's the payoff?
Old Jan 28, 2006 | 08:54 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Default HIGH FLOW CATS..what's the payoff?
stock motor,vortex ram air, b&b shorties (yea, I know) , corsa x pipe, corsa indy system. Adding high flow cats gets me what?
RT is telling me I'll get 10-20 rwhp ? Sounds like quite a stretch to me....
Old Jan 28, 2006 | 08:59 PM
dpd's Avatar
dpd
other than maybe $500.00 shorter probably nothing considering your setup.if you went to long tubes they would help,no disrespect intended.
Old Jan 29, 2006 | 12:34 AM
Dark-Knight's Avatar
Dark-Knight
Hi-flow cats are not as restrictive as stock cats, helps get the bad stuff outa the motor faster! They are a good compliment to L/T headers.
Old Jan 29, 2006 | 02:56 AM
mrm1149's Avatar
mrm1149
In short(not a pun), with my current setup all I'd really get out of the high flows is a different sound? No seat of the pants benefit?
Old Jan 29, 2006 | 03:00 AM
mdhmi's Avatar
mdhmi
Very little benefit with a stock setup.
Mark
Old Jan 29, 2006 | 04:04 AM
bayarea's Avatar
bayarea
say with your current set up you were at 335rwhp with replacing the stock cats with high flow cats I'd say your lookin at 337rwhp
Old Jan 29, 2006 | 04:46 AM
mrm1149's Avatar
mrm1149
Quite a gain I'm gettin the drift here... worth anything as a deeper/louder exhaust note?
Old Jan 29, 2006 | 01:07 PM
mrm1149's Avatar
mrm1149
more thoughts...........
Old Jan 29, 2006 | 02:39 PM
bayarea's Avatar
bayarea
get some longtubes hookem up to an x pipe and put on corsa catback or in my opinion a borla straight pipe cat back. then go go get a cam installed.
get rid of those shorty's you definetly do not need those
Old Jan 29, 2006 | 03:42 PM
mrm1149's Avatar
mrm1149
Hmm.........
Old Jan 30, 2006 | 05:32 AM
mrm1149's Avatar
mrm1149
Seems to be not really worth anything with my current setup?
Old Jan 30, 2006 | 06:56 PM
mrm1149's Avatar
mrm1149
added info re: RT opinion..
Old Jan 31, 2006 | 01:42 PM
David Borla's Avatar
David Borla
Premium Supporting Vendor
According to ferderal regulations, it is not legal to replace a catalytic converter unless it has been proven by technician to have failed, and then it can only be replaced with an exempt OEM equivalent unit.
Difficult to enforce but the law states that; unless you have documented proof from a licensed technician stating that your cat "failed", a cat replacement is just as illegal as cat elimination.
Furthermore, even if your cat(s) "fails" the law states that you must replace it/them with an "OE equivalent" not a "high flow". So, a "high flow" will get you in as much trouble as just getting rid of the cats entirely.
The EPA will not only fine the enthusiast for this, they will also fine the installer.
Please be careful........
Old Jan 31, 2006 | 03:17 PM
Heretic's Avatar
Heretic
The federal regulations are toothless. The State gov't (part of their revenue stream) is responsible for enforcement. LS1 Edit, cam swaps, head swaps (even installing GM LS6 heads/cam on a LS1 car) are illegal as well, so is installing an exhaust that would cause the car to fail the Federal noise tests BTW.
I know for a fact that in most states if they see a bulge in the pipe, no SES light, and IM 240 or sniffer pass, that you've passed emissions. Colorado does not even inspect for EGR and AIR pumps anymore, they would have to train the monkeys so they could properly distingish a lug nut from an AIR pump.
This law exists to keep manufacturers in check. Do you really think they would fine someone for replacing a cat? Factory cats have a long history of "falling off" and being replaced with aftermarket high flows.
Old Jan 31, 2006 | 06:17 PM
David Borla
I agree. As I mentioned this law is difficult to enforce.
Old Jan 31, 2006 | 06:52 PM
David Borla
Good question, I don't know?
I wonder what the results were with this specific instance? Please see below
http://forums.stangnet.com/showthread.php?t=571395
To HIGH FLOW CATS..what's the payoff?
