HELP, Idle problem
Old Jan 29, 2006 | 02:31 PM
racer959's Avatar
racer959
Default HELP, Idle problem
When I come to a stop, the idle stays a little above 2000 rpm for about 10 seconds and then comes down, can someone help me, thanks (02 Z06 head & cam package 510HP)
Old Jan 29, 2006 | 02:38 PM
dpd's Avatar
dpd
sounds like your tune is off.i'm assuming you had it tuned anyway.but what you are describing it sounds like your tune[idle circuit] is off.
Old Jan 29, 2006 | 02:57 PM
racer959's Avatar
racer959
Thanks, is there some kind of idle control sensor that would cause this
Old Jan 29, 2006 | 03:00 PM
dpd's Avatar
dpd
no sensor,some of the parameters between the tac/pcm modules need to get tweaked.DO NOT LET anyone drill a hole in the throttle blade.it can be done by tweaking some of the parameters,it takes some time,but can be done.
Old Jan 29, 2006 | 07:36 PM
VetteTech81's Avatar
VetteTech81
Is this a new problem?
Or has it been this way right after the heads and cam?
Or did you install anything recently before this problem showed up?
-=Rick
Old Jan 29, 2006 | 07:37 PM
VetteTech81
Yes def. DO NOT drill a hole in the throttle plate, but with his problem of the car idling HIGH, it would make it worse as more air would flow past the throttle body at idle.
-=Rick
Old Jan 29, 2006 | 07:49 PM
Patches's Avatar
Patches
I knocked my Idle Airflow and Idle Airflow Parked values down between ~8-68 deg. C to eliminate that cruise control effect.
Old Jan 30, 2006 | 08:28 PM
racer959's Avatar
racer959
Heads and cam were done in 02, this is a new problem, did not add anything else since then
Old Jan 30, 2006 | 08:39 PM
dpd's Avatar
dpd
is the throttle housing gunked up[blade sticking]? but from what you are describing it almost sounds like a bad tune.could be a slight air leak after the maf and before the throttle but i would think you would throw a lean/maf type fault.another possibility would be a pcv valve sticking,but you should also be sucking oil out of the motor
To HELP, Idle problem
