Emergency brake light coming on
Old Jan 29, 2006 | 10:47 PM
gbm's Avatar
gbm
Default Emergency brake light coming on
Anybody had this one? - My emergency brake light is coming on when I accelerate and now more often than not. Any advice on what to check or what to do?
Old Jan 30, 2006 | 10:17 AM
J.M.G.'s Avatar
J.M.G.
Please have a look in your manual, Page 2-84:
Brake System Warning Light
Your vehicle’s hydraulic brake system is divided into
two parts. If one part isn’t working, the other part can
still work and stop you. For good braking, though, you
need both parts working well.
This light should come on
when you turn the ignition
key to START. If it doesn’t
come on then, have it fixed
so it will be ready to warn
you if there’s a problem.
If this warning light stays on after you start the engine,
the parking brake may still be set or there could be a
brake problem. Refer to “Parking Brake” in the Index to
see if it is set. If the parking brake is not set, have your
brake system inspected right away.
If the light comes on while you are driving and you have
a LOW BRAKE FLUID message showing on the DIC,
pull off the road and stop carefully. You may notice that
the pedal is harder to push. Or, the pedal may go closer
to the floor. It may take longer to stop. If the light is still
on, have the vehicle towed for service. See “Towing
Your Vehicle” in the Index.
Old Jan 30, 2006 | 03:13 PM
Face's Avatar
Face
Check your brake fluid level.
Old Feb 3, 2006 | 02:03 PM
gbm's Avatar
gbm
Thanks Face. Hit it on the head. fixed
Old Feb 3, 2006 | 07:01 PM
turboc5's Avatar
turboc5
FYI if its low you probaly need brake pads. Or it leaks
To Emergency brake light coming on
