problem with CLB
Old Jan 30, 2006 | 12:58 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default problem with CLB
I installed one on my 97 about 3 months ago and every time I take the keys out and then put it back in I get a pull key message. If I don't ever take the key out of the ignition I never have a problem. Is this something that is normal for the 97 ?
Old Jan 30, 2006 | 06:43 AM
cenzo's Avatar
cenzo
When the security system sees multiple key insertions in rapid order it senses there's foul play (theft attempt) and you'll get that warning. It happens to me if I insert the wife's key by mistake then immediately insert mine. Of course, it could be something else, but I doubt it if it only happens under the circumstances you describe.
Old Jan 30, 2006 | 08:24 AM
mvvette97's Avatar
mvvette97
Well I guess what I mean is if I pull the keys and go in to a store or something then when I come back out and put the key back in I will get the message every time.
Old Jan 30, 2006 | 08:44 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
maybe disconnect the CLB and reinstall to see if it will fix your problem
Old Jan 30, 2006 | 09:18 AM
molson's Avatar
molson
You might try cleaning the resistor in your key.
I have heard of similar problems caused by dirty contacts on the key.
Old Jan 30, 2006 | 09:24 AM
mvvette97's Avatar
mvvette97
I never thought about that. I'll try it and see what happens.
Old Jan 30, 2006 | 09:46 AM
cenzo's Avatar
cenzo
You must have missed rapid order. And I must have misunderstood the meaning of "in and out." Sorry
Old Jan 30, 2006 | 10:27 AM
mvvette97's Avatar
mvvette97
No problem man. I should of made it more clear. I'll clean the key and unhook the bypass and then see what it does.
To problem with CLB
