tires
Old Jan 31, 2006 | 04:40 PM
itchy_c-5's Avatar
itchy_c-5
Default tires
If I choose not to use run flats do I have to leave the tpms sensors in the tire?
Old Jan 31, 2006 | 05:04 PM
patrickC5's Avatar
patrickC5
Yes I believe you can run tires with out the sensors but you will get a note about it on your display every time you start the car but you can just reset it every time. Chime in guys if I am wrong.
Old Jan 31, 2006 | 05:31 PM
Billdog350's Avatar
Billdog350
It is strongly recommended to use the sensors even if you don't have runflats on the car.
Patrick is right, you will have a warning message on your DIC every time you start the car if the sensors are removed. You can clear it with the reset button but it is definitely annoying.
I have heard that you cannot tune that feature out with programming so ask yourself if you feel like hitting that button every time you get in the car for the next X amount of time.
Old Jan 31, 2006 | 05:39 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Why would you want to do this?
The tire pressure system is a plus to any car with no spare tire. It gives early warning of a potential problem before the problem become dangerous. With an under-inflated tire reaches to threshold of being unsafe, the only way you will know it is when the car becomes unstable.
This occurs around 10 psi... People only think of a flat as an inconvenience when you come out and see the tire is flat. Most flats occur while picking up a road hazard. Most tires do not blow out like the old days, they develop a slow leak usually from picking up a nail, then the air leaks out to a point where the car can get out of control... Having the tire pressure monitoring system in the car, the DIC will display a tire at 25 psi, at this point you know you have a problem, but the car will seem fine. At this point you can stop the car and add some air to travel to your destination or to a safe haven to get the tire fixed.
With out the sensors, you only know it when the car becomes unstable, and this usually means a quick exit and the loss of an expensive tire. There is no good reason Not to use the sensor system.
Old Jan 31, 2006 | 05:43 PM
JR_VET's Avatar
JR_VET
Old Jan 31, 2006 | 05:49 PM
plaster's Avatar
plaster
Originally Posted by Billdog350
...I have heard that you cannot tune that feature out with programming so ask yourself if you feel like hitting that button every time you get in the car for the next X amount of time.
I was told by my tunre that it could be cleared. However, he did not clear it
To tires
