Need Injector Flow Rate setting for 30lbs Injectors
Old Feb 1, 2006 | 11:09 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Default Need Injector Flow Rate setting for 30lbs Injectors
Getting ready to upgrade my injectors, anyone know what the Injector
Flow Rate needs to be adjust too for 30lbs injectors?? I'm using LS1Edit.
Old Feb 2, 2006 | 10:39 PM
Vetteran's Avatar
Vetteran
ttt
Old Feb 3, 2006 | 03:10 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Use this spreadsheet. You;ll need to know what fuel pressure they were rated at (probably 43.5 PSI).
http://www.transamws6.net/HPTuners/injectors.xls
Old Feb 3, 2006 | 07:42 PM
gojo's Avatar
gojo
If you're using SVO's and tune with HPT or EFI send me your e-mail and I'll send you a "copy and paste calculator" with the right #'s.
Otherwise use these numbers in the calculator in the previous post.
Injector Rated Fuel Pressure.-40
Your fuel rail pressure.-------58
Injector rated Flow Rate_____30
Old Feb 8, 2006 | 12:14 AM
Vetteran's Avatar
Vetteran
Thanks guys!!
To Need Injector Flow Rate setting for 30lbs Injectors
