I am placing a cam in my LS6 motor and the heads are stock and the cam spec are 228/228 585 LSA 112. I knew I had to replace the the stock springs. So I just purchased a set of AFR dual valve springs from a CF Member and a set of retainers from Andy at A&A. Will they work on a set of LS6 243 stock heads? I know this is a bad time to asked the question but. If the springs don't have a spec sheet where can I go to find the seat pressure, bind pressure and othe specs I need to know? or should I resale the springs and retainers and buy a set from GM. Or can some recommend a set that will fit the LS6 heads.
These are the springs on my AFR 205's. I don't see any reason why they wouldn't work if they are in good shape. Hope this helps
Thanks I did a search before I posted the thread but I quess I didn't look long and hard enough. But you have provided me with the info I needed to know. Thanks ArKay99
J.R
