My car is giving me these codes
C2120 TPM System Malfunction (No Sensors Received)
C1286 Steering Sensor Bias Malfunction
P1545 A/C Clutch Relay Control Circuit
P1546 A/C Clutch Status Circuit Low Voltage
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
I just had a 383 built, so these are the codes it gave me since being finished. Insight?
your check engine light is from the o2 fault,check to make sure the left side o2 harness[front]isn't laying on a header[if the fuse was blown],you could also have a lazy sensor,but that wouldn't blow the fuse.don't know what happened to the old motor,but if the fuse was melted and the a/c doesn't work and the system is filled i would look at that underhood fuse block[a/c fuse/compressor relay is in it]to see if anything else is burnt up. the stering angle sensor fault is from the ebcm seeing more than a 40 degree ovement one the wheel is centerd.are you sure the steering shaft to rack alignment is right.if it's off you will get that fault.try and reteach the tpm's.
don't know who did the work,but if you paid someone i would go back and give them the WTF!
