HELP!!! Check engine light flashing on WOT!!!!!
Old Aug 8, 2001 | 03:07 AM
akw408's Avatar
akw408
Default HELP!!! Check engine light flashing on WOT!!!!!
Does anyone have a clue as to why this is happening??? . It ONLY occurs when I hammer it. If I stay in a certain gear, and gradually take it to redline, then shift it won't come on. No codes show when I go through the DIC as well. Maybe a high rpm misfire? Could it possibly be a bent pushrod!?!? I have read that the stock push rods on a C5 don't hold up well to constant high rpm use. Any help would be appreciated. Thanks.
Old Aug 8, 2001 | 04:30 AM
BruceF's Avatar
BruceF
Default Re: HELP!!! Check engine light flashing on WOT!!!!! (akw408)
A flashing CE light is usually indicative of a misfire. The first place to look is the plug wires. Make sure they are all on tight.
Also, check the codes and post them here. https://www.corvetteforum.com/guides...s/ipccodes.htm
