Old pump pressure
Old Feb 2, 2006 | 11:49 PM
1Sonny's Avatar
1Sonny
Default Old pump pressure
Just got my motor redone on my 2004 vette. Oil pressure is 9 to 11 psi on idol. Shop tells me that's OK. I say is not. I say it should be 25 to 27 on idol. I don't think the motor was done rite. I think it could be a bad oil pump. They also tell me that the machine shop say's it OK.
I'm Not Happy need help.
Thanks Corvette Family
Old Feb 3, 2006 | 01:12 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
sounds like it has too much clearance in the bearings. That is very low for a new engine. I also would worry.
Old Feb 3, 2006 | 07:41 AM
dpd's Avatar
dpd
oil pressure is too low,be it bearing clearances,solid lifters,etc. more than likely though the o-ring that goes on the pick-up tube to the oil pump is cut[if the motor is knocking/clicking/tapping/etc].if the o-ring is not cut,you have motor problems.
Old Feb 3, 2006 | 08:11 AM
DSCHULTZ's Avatar
DSCHULTZ
I Had same problem when did head cam install put in ported ls6 oil pump problem fixed.
Old Feb 3, 2006 | 11:58 AM
Jim Taylor's Avatar
Jim Taylor
I just did heads/cam and replaced the stock oil pump with a ported LS6 pump. My pressure at idle is 40+. Responses above sound right, but what a PITA to go back into the engine and fix it. Hope you can convince the shop to do it.
Old Feb 3, 2006 | 07:35 PM
1Sonny's Avatar
1Sonny
You and I feel the same way guys. Thank, For your advise. Andy of A&A thank you too. You guys are the best.
Old Feb 3, 2006 | 07:42 PM
1Sonny's Avatar
1Sonny
theres no knocking-clicking or tapping but it still not rite.
To Old pump pressure
