Power Programmers for '98 C5
Old Feb 3, 2006 | 01:14 PM
ESCAPEDGREG's Avatar
ESCAPEDGREG
Default Power Programmers for '98 C5
I have a '98 C5 and was waundering what type of programmer is available. I know the predator only works on 99's and up. Any info would be great. Thanks Greg....
Old Feb 3, 2006 | 01:59 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
If you are talking about a handheld unit Hypertech is the only one you can use, I had one it worked great for the price, just used it for fan progaming ,shift points, rev limit. I did not use the engine tuning feature but it has that too.
Good luck
Old Feb 3, 2006 | 02:31 PM
lost's Avatar
lost
Good luck
I figure i picked up 5-10 hp with my Hypertech, other features made it worth the used price I paid
Old Feb 3, 2006 | 04:01 PM
cruzn57's Avatar
cruzn57
Default what he said
I use a hypertech tuner for fan temps, but one day started fiddling with other prameters, and wow, actually runs harder, ( or so it feels)
so.......... use for fans anyhow!
Old Feb 3, 2006 | 06:47 PM
PGann's Avatar
PGann
If you are talking about a handheld unit Hypertech is the only one you can use...
Actually, there is another one that someone posted about the other day. Do a seach for VHP Tuner. They have a hand-held model for the '98. I think it goes for about $429, which is more than the Hypertech unit. I think it may do "a little" more than the Hypertech.
Don't pay the full $399 for the Hypertech. I did a seach on the Net and the lowest new price I found was (I think) $287.
Old Feb 4, 2006 | 08:49 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
As winter wears on, keep your eyes open on here.... you'll pick up a used hypertech for around $120 or so... great place to start putzing around but only a few things you can do for an A4 if that's what you have.. Shift firmness is a good one!
Old Feb 4, 2006 | 12:02 PM
Face's Avatar
Face
Don't bother if you don't have a A4. The tuning did absolutely nothing for me. The best feature was being able to raise my rev limiter and shift points. Lowering the fan turn on temps was also a good thing too.
You'd be better off with a mail order tune or much better off with someone local that does wideband dyno tuning.
Old Feb 20, 2006 | 12:21 AM
SLPRC5's Avatar
SLPRC5
I agree...I have a '97 and was told that the '97 cannot be dyno tuned because of the limited OS. So it was recommended to upgrade to a '98 OS. I just removed my PCM and sending it in to be reprogrammed by this company.
http://www.wait4meperformance.com/
Old Feb 20, 2006 | 06:31 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Regarding the Vinci/Crane programmer/tuner......... I just recently purchased one and can confirm it`s the "REAL DEAL!"
I have a 98 vert A4, 3:15 gears with QTP Tri-y`s, Random Tech converters/x-pipe, B&B Bullet cat-back, Vararam, LS6 intake, Iridum plugs, 160*thermostat, etc.
With the Hypertech tune: from a standing start with just enough brake to spool up the stock converter, almost no wheel spin, slight bog off the line until rpm`s kick in, no spin/chirp into 2ed and again pulled hard once the rpm`s kicked in.
With the Vinci/Crane tune: HUGE DIFFERENCE, again from a standing start, aprox same temp/conditions, car left hard, laying down two nice patches as it accelerated strongly up to 2ed, shifted strong into 2ed leaving a couple short patches and continued to pull very strong all the way through top gear.
I bought this tuner with some skepticism, as I did not want another Hypertech...... needless to say, I trusted Roger & Joe Vinci and they did not disappoint!!!! This thing "really woke up my car"!
Just remember, like with any tune, your gains will depend on intake and exhaust restrictions/improvements.
I`ll be heading for the dyno in a week or two, so we`ll see what gains I get. Previous dyno results: 333.53rwhp 342.43rwtq
Rick
P.S. I have a Hypertech for sale (inclds original box, manual) fits 98 model ONLY, I`d like $200.00 for it, send me a pm if interested.
Old Feb 20, 2006 | 07:18 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Rick
Thats good to hear.I just sent mine back to Joe,Because I had a OS error,So hopefully they can program it to work on my car.I just did H/C & headers so I should benifit from it.I have a 97 auto.
Old Mar 3, 2006 | 03:16 AM
SLPRC5's Avatar
SLPRC5
If they can't program your tuner (Superchip uses the '97's VIN# and you can only use it on that car) you can remove your PCM and send it in to have a mail order tune put in it and the OS for a '98, then tuners have more options to work with.
I just had mine done at
http://www.wait4meperformance.com/ for $83.00.
Rsty
Old Mar 3, 2006 | 03:07 PM
Rag-Top Rick
Going to dyno my 98 vert tomarrow, if it doesn`t rain!
SOTP feels like I pick-up some pretty good gain using the Vinci/Crane tuner.... will advise.
Rick
Old Mar 3, 2006 | 04:14 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Rsty
I'll keep that in mind,Thanks..............Paul
Old Mar 3, 2006 | 05:08 PM
ZBrink's Avatar
ZBrink
St. Jude Donor '06
I have a 98' Auto and I have used the Superchips program for probably four years now. I have somewhat mixed feelings about it. The car definitely pulls harder and the shifts are quite firm and can really chirp the tires through all the gears on a hot summer day.
However, my RPMs seems to get slightly choppy at idle and when in low RPM range on occasion, but not all of the time. So I wonder about this sometimes. If I planned on doing more mods, I would definitely go with a custom program but right now funds are low and the Superchips is better than stock in my opinion. I think I got mine on special for less than $300 if my memory serves me correct but that was several years ago.
Old Mar 3, 2006 | 06:09 PM
Rag-Top Rick
The symptoms you speak of are a few of the reasons I went with the Vinci/Crane programmer.
You have infinite adj on the A/F ratio, several idle settings, several timming settings, etc, etc.
I`ll let everyone know the dyno results on Mon-Tue.
Rick
Old Mar 3, 2006 | 08:01 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Rick
I got my VHP programmer back,but they forgot to send the cable .Rick let me know how you make out on the dyno...Thanks.....Paul
To Power Programmers for '98 C5
