LS2 HEADS on a LS1
Old Feb 3, 2006 | 03:39 PM
Gee3's Avatar
Gee3
Default LS2 HEADS on a LS1
Does anyone know FOR SURE if LS2 heads from a 2005 Corvette will fit on a 2001 LS1. I heard they would and are worth about 25 HP.
Old Feb 3, 2006 | 04:43 PM
mdhmi's Avatar
mdhmi
The heads will fit, but wont add 25 hp to a bone stock car.
Mark
Old Feb 3, 2006 | 04:56 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Mark
Ok, but what will they do for a bone stock car?
What else needs to be done to the LS1 in order to use the LS2 heads?......surely you don't just bolt them on and drive off, do ya?
And for an LS1 that has a mild street cam and headers, is it worth the effort to add the LS2 heads?
Just sitting here eating my popcorn, and wondering.
Old Feb 3, 2006 | 05:15 PM
chriswtx's Avatar
chriswtx
LS2 heads are the same port design as LS6 heads. I think they are the same castings... Just the LS2 heads have solid valves where the LS6 heads have hollow valves..
Old Feb 3, 2006 | 05:33 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
You are right on both occasions!!!
Old Feb 3, 2006 | 05:44 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I second that!!!
Different valve springs too, because of the lighter valves.
Randy
Old Feb 3, 2006 | 05:53 PM
Casem1's Avatar
Casem1
I can tell you what they are worth in a few weeks. I placed my order today for LS2 heads and a TSP cam. From the dyno charts I have seen the LS6 (LS2) heads will actually support some pretty hearty setups. To each his own, I am not trying to make a 10 sec car.
Old Feb 3, 2006 | 06:35 PM
turboc5's Avatar
turboc5
Old Feb 3, 2006 | 10:11 PM
Shane_S's Avatar
Shane_S
I think i heard somewhere that they use a slightly different legnth valve then the LS6 head and therefore need a different legnth pushrod. Anybody else read that anywyere? Or am i just dreaming crap up? lol
Shane
Old Feb 3, 2006 | 10:29 PM
BoiseVette's Avatar
BoiseVette
Hi Shane,
I was just checking your dyno link on the "before and after LG header swap". Was that all that was done to get the extra 31 hp/38 torque? Was the rest of the exhaust stock? Was there a tune done after the swap?
Nice numbers if it was only the headers. Is that typical for that upgrade?
I'll be interested to hear the details.
Thanks,
Keith
Shane
Old Feb 3, 2006 | 10:38 PM
chriswtx's Avatar
chriswtx
Yes, LS6 valves are a different length. The pushrods are same as LS1 and they made up the difference with a different base circle on the cam...
Old Feb 3, 2006 | 11:09 PM
fdxpilot's Avatar
fdxpilot
Originally Posted by BoiseVette
Hi Shane,
Thanks,
Keith
Shane's numbers are about right for LG LTs with a tune. With that setup, I went from 310 rwhp/328 rwtq to 340 rwhp/354 rwtq. That's on an 02 MN6 with hi-flow cats and LG doing the tuning.
Old Feb 3, 2006 | 11:12 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the 2001 valves are not sodium filled, and the the valves are the same length as ls1, the .525 cam doens't use a different base circle, correct me if i'm wrong
the 243 castings are the same 01-06, 'castings'
Old Feb 3, 2006 | 11:55 PM
BoiseVette's Avatar
BoiseVette
Thanks!
Old Feb 4, 2006 | 02:29 AM
Shane_S's Avatar
Shane_S
Thanks for the assist.
Yep, headers & tune. Not bad for a ~100k mile car that was stock its whole life before i got it.
Shane
Old Feb 4, 2006 | 08:18 AM
Gee3's Avatar
Gee3
Default LS2 heads on LS1
Thanks for all the replies. So when I install the 05 heads on my 01 do I need to change the push rods. Anything else needs to be changed ?
Old Feb 4, 2006 | 08:23 AM
Shane_S's Avatar
Shane_S
I believe in 02 the casting changed very very slightly but still kept the #243 casting number. That's also when the LS6 started coming with the Yellow springs if i remember correctly. Although I could be wrong on that one.
Shane
To LS2 HEADS on a LS1
Old Feb 4, 2006 | 09:02 AM
byte_me's Avatar
byte_me
Shane
I just bought a set of NEW LS6 heads from a forum member who purchased the 04 crate engine over a year and a half ago- the springs are not yellow, they are steel color with a blue paint line down one side. They are casting number "243" so I guess GM has is was switching springs on engines.
Old Feb 4, 2006 | 09:09 AM
SteveDoten's Avatar
SteveDoten
more yellow spring confusion, i've got yellow springs from an '02 and an '05, the blue stripe springs seem to be mixed in randomly
Old Feb 5, 2006 | 12:49 AM
turboc5's Avatar
turboc5
I bought brand new ls6 springs from gm last summer and they were blue.
