Removing LG headers from bottom
Old Feb 4, 2006 | 01:58 PM
Phil97SVT's Avatar
Phil97SVT
Default Removing LG headers from bottom
Can anyone tell me if you can simply unbolt the passenger side LG header and remove it from the bottom of a C5 without removing any other items?
Phil
Old Feb 4, 2006 | 02:01 PM
dpd's Avatar
dpd
it comes out through the top.it's not coming out or going in through the bottom.
Old Feb 4, 2006 | 02:51 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
installed mine through the bottom
Old Feb 4, 2006 | 03:10 PM
402Sam's Avatar
402Sam
As did I, but I think I had a problem geting it all the way up due to the starter.
Old Feb 4, 2006 | 03:55 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
You can take the driver side out through the bottom but in order to take the passenger side out through bottom you will have to undo the starter
Old Feb 4, 2006 | 04:10 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Which is what I did. However, Lou said only some cars require that, others it works fine.
Old Feb 4, 2006 | 06:12 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Why remove the starter? Would be easier just to unbolt the valve cover and pull it out from the top. Takes about 5 minutes to pull the coil pack and cover.
Old Feb 4, 2006 | 07:08 PM
Phil97SVT's Avatar
Phil97SVT
They won't come out the top with the new ET heads.
Phil
Old Feb 4, 2006 | 09:13 PM
Cajundude's Avatar
Cajundude
Phil
Didn't know that. In that case, I would say you definitely need to remove the starter and jack the car up at least 20 inches in the front. Gonna be tight but it might go.
Old Feb 4, 2006 | 10:25 PM
WKMCD's Avatar
WKMCD
Phil
AARRGGHHHHH!!!!!
Old Feb 5, 2006 | 01:34 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
I thought we need to remove the headers to remove the starter. I did replace my stater couple months ago and have to pull the headers completly out.
I guess y'all can just unbolt the headers and put them aside to remove the starter.
Good thing to know.
-Mike
Old Feb 5, 2006 | 01:37 AM
FactoryRaceCar
Jason go back to the garage and finish that 402 TT already
To Removing LG headers from bottom
