Different MAF Sizes?
Old Feb 5, 2006 | 03:24 PM
Too Slow '90's Avatar
Too Slow '90
Default Different MAF Sizes?
Is the Zo6 MAF a different size than a regular C5 MAF?
Old Feb 5, 2006 | 03:31 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Z06 is 5 pin 85mm and it was descreened in 02 onwards If you are doing a conversion you need to either buy the adapter wiring harness and LS1 calibrated MAF or buy a non calibrated one and then use a tuner/software to change your PCM's table over to the new MAF table. You would still need a harness though
Old Feb 5, 2006 | 03:43 PM
Too Slow '90
Thanks. My problem is that while installing a stinger from a Z on my brothers '00 coupe we have found that the opening in the "warhead" filter is much bigger than the MAF but I have not found any info saying that the stinger is different for a coupe and a Z.
Old Feb 5, 2006 | 03:48 PM
FactoryRaceCar
I am pretty sure they make an adapter for this. You might want to look into it. Sorry to answer your original question I think it 78mm vs 85mm
To Different MAF Sizes?
