Engine stumbling/flat on acceleration
Old Feb 6, 2006 | 05:38 PM
Mike Schriber's Avatar
Mike Schriber
Default Engine stumbling/flat on acceleration
I had my '99 Coupe parked for three weeks and I just started driving it again. I first noticed the engine stumbling a few times when starting from a stop. Today it did it again so I experimented a bit. It stumbles slightly from idle if you jab the throttle. It also stumbles and feels obviously flat on hard acceleration at speed.
I took a look around and everything seems to be in order (the intake isn't loose or any other common problems). The idle is smooth and constant. I did have it off the battery so the computer probably reset. Maybe it's going through it's learning process?
Anyone have any thoughts?
Thanks!
Mike
Old Feb 6, 2006 | 06:15 PM
dpd's Avatar
dpd
yes,it will relearn,but the motor shouldn't nose over or stumble.any faults? while it was parked,did any critters get in and knaw anything?
Old Feb 6, 2006 | 06:49 PM
Mike Schriber
No critters. I just had the time to run out and check the codes. I see a PCM code of P1111 (intake temperature sensor intermittent high voltage) which could explain it. However, it was a history code so it dosen't seem like a current issue.
Mike
Old Feb 6, 2006 | 07:09 PM
dpd's Avatar
dpd
yea,intake air temp influences ignition timing.
Old Feb 6, 2006 | 10:01 PM
Alfcarguy's Avatar
Alfcarguy
Try some gas treatment to get any water/condensation out of the gas if there's any in the gas. You did say its been sitting?
Old Feb 7, 2006 | 12:59 PM
lotzahp's Avatar
lotzahp
I had similar symptoms a while back - it was misfire. I had no misfire codes, it had to be monitored while running.
The cause ended up being a fouled fuel injector. After it was cleaned out, I replaced the fuel filter and everything has been fine.
Old Feb 7, 2006 | 03:19 PM
Mike Schriber
It didn't feel like a misfire but I'll do some research. It only sat for three weeks... I've had it parked for much longer before without issues.
I've been meaning to replace the plugs anyway so I'll get off my rear and do it. I already have a set of the new pre-gapped GM iridium plugs sitting in my garage. My NGK coppers should still be good but I did a lot of racing on them so I decided to switch (it's a street car only now).
Any recomendations as to fuel system maintenance? Is there an additive (something I usualy avoid) that works well in Corvettes for cleaning the injectors and such?
Thanks for all the info!
Mike
Old Feb 7, 2006 | 06:10 PM
Alfcarguy's Avatar
Alfcarguy
B12 chem tool you can get it at Wal-mart or auto part place. Pour in fuel tank with full tank and it also cleans the injectors. They usually come in 12oz cans. Good look
To Engine stumbling/flat on acceleration
