Need C5 front caliper torque specs ASAP!
Old Aug 8, 2001 | 06:43 PM
GTP's Avatar
GTP
Default Need C5 front caliper torque specs ASAP!
Need vto know the torque specs for the front caliper and caliper bracket on a C5. Installing my Eradispped rotors and don't wanna screw up. Also whats the proper torque for wheels....I think its 25, 75 then 100ft lbs in a star patern......that right?
Thanks allot guys......typing with 1 hand is bad enough from a broken thumb.
Aaron Lephart
Old Aug 8, 2001 | 09:10 PM
Bob C's Avatar
Bob C
Default Re: Need C5 front caliper torque specs ASAP! (GTP)
Brake caliper bolt is 23 Ft. Lbs. Wheel lug nut 100 Ft. Lbs. Your description of how to do it is great.
Old Aug 9, 2001 | 12:20 AM
Capt Ron's Avatar
Capt Ron
Caliper bracket torque spec: 125 ft-lbs.
Old Aug 9, 2001 | 12:37 AM
Bob C's Avatar
Bob C
Default Re: Need C5 front caliper torque specs ASAP! (Capt Ron)
Capt Ron
You are absolutely correct, I confused his request with the guide pin torque. Thanks for clearing that up.
Old Aug 9, 2001 | 01:16 AM
GTP's Avatar
GTP
Thanks very much guys, I really appreciate it. I'm going to install the rotors right after work.
Thanks,
Aaron Lephart
To Need C5 front caliper torque specs ASAP!
