Installing a Callaway - Any problems?
Old Feb 6, 2006 | 11:20 PM
1FUNVTT's Avatar
1FUNVTT
Default Installing a Callaway - Any problems?
Just got a Callaway Intake; For those who did their own install, was there any unexpected problems? Or anything I should know about that will make this install easier?
Greg
Old Feb 7, 2006 | 05:43 PM
mcv's Avatar
mcv
Greg
Thanks for your interest, Greg.
Hope these instruction sheets help explain:
Honker Installation Instructions, 1997 - 2000 Corvette
Honker Installation Instructions, 2001 - 2004 Corvette
Old Feb 8, 2006 | 03:02 AM
striper's Avatar
striper
I installed my Honker on my Z06. If you follow the instructiuons carefully and take your time you will have no problems. One tip, get everything re-assembled totally leaving all fasteners loose until everything is aligned. Then you can tighten it all up with no fitment problems. Good choice, it works great and looks like a factory installation.
Old Feb 9, 2006 | 11:06 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
The instructions that come with the honker are great.
I have noticed one thing though and wanted to see if anyone else has noticed this. The wiring harness that attaches to the MAF sensor is touching and punched a small in the hood insulation. Anyone else notice this? And yes, the intake is sitting on the pins.
Old Feb 9, 2006 | 05:21 PM
1FUNVTT's Avatar
1FUNVTT
Thanks guys for the posts... anymore info or experences
Ordered another radiator shroud for my cut-out...
Are you guys running a bottom radiator screen with your callaway?
Old Feb 9, 2006 | 11:14 PM
striper's Avatar
striper
Yes, I also installed a lower radiator intake screen at the same time. I made my own with material I purchased at Home Depot. An $8 sheet is enough material to make screens for 6 cars. When you have the shroud out it will be the perfect time to clean out your radiator and in between the radiator and A/C condensor.
Old Feb 11, 2006 | 12:15 AM
deadbolt67's Avatar
deadbolt67
Main thing is to take your time. The Callaway instructions are great, but you only have one shot at getting it right. Test fit, measure, measure, mark, test fit, recheck, cut.... Mine sits right on the pins; but the grommets are so tight that it does not bottom out on them.
Good luck with your installation. You will enjoy the end result.
To Installing a Callaway - Any problems?
