Problems with my HID's ...
Old Aug 8, 2001 | 09:53 PM
MDL-01C5's Avatar
MDL-01C5
Default Problems with my HID's ...
Over the last couple of weeks, my HID's(Philips w/T-84)have stopped working properly. When I got them, I had a problem with the pass side ballast getting water in it, which I performed a jury-rigged fix using silicone sealant. No problem.
Lately, however, I noticed that when I would go to first turn them on, at least one of them would hesitate to come on....as though there wasn't enough current to ignite the bulb.
This had deteriorated gradually to the point that I can't even drive at night anymore, because if I get the damn things to light in the first place, the lightest bump or bounce causes one or both of them to go out :mad
I feel this is somehow related to the power system, since the problem is somewhat worse with the a/c and/or stereo on.(If either of the above items are on when initially turning on the heads, they WILL NOT come on at all--I have to turn off both the ac & stereo to light them at all:rolleyes: )
My question is this... Why would I have had no problem whatsoever for half of a year, and the a complete failure of the system?
I haven't changed anything on the car in that time, other than adding the stereo four months ago-- back when I had and continued to have no problems :confused: so I don't think that was what did it....
Any advise would be greatly appreciated....
I paid way too much for these things(which I absolutely LOVE when working properly:D ) to have them quit working.
Old Aug 8, 2001 | 10:36 PM
CRUZMISL's Avatar
CRUZMISL
Default Re: Problems with my HID's ... (TexasRedY2K)
I'm no expert either but be sure to check for a poor ground. When I did stereo installs that was a major factor in returns. I don't know how they wire up but might be something you want to check. It sounds like a short somewhere if it goes out when you hit a bump. These are a real PITA to sort out. Good luck.
BTW in order to check for a good ground find out where the headlights are grounded and take a meter and put it on Ohm reading. Touch one probe to the light ground and the other to the battery ground. You shouldn't see more than 1 ohm resistance. If you do you should look for another ground.
Good luck,
Joe
Old Aug 8, 2001 | 11:29 PM
jetskifast's Avatar
jetskifast
Default Re: Problems with my HID's ... (MDL-01C5)
Sounds like a ballast problem. Once ballasts are fired up they draw very little current.
You may also have a connection problem somewhere, since bumps are giving you problems.
By the way my HID lights are still working great
Old Aug 9, 2001 | 12:06 AM
MDL-01C5's Avatar
MDL-01C5
Default Re: Problems with my HID's ... (jetskifast)
Thanks for the responses, guys, and keep them coming
I have a feeling this is going to take a while to figure out....
Old Aug 9, 2001 | 12:11 AM
EHS's Avatar
EHS
:rolleyes: :cry :sleep: :lol: :bs :D
:seeya
Old Aug 9, 2001 | 01:40 AM
MDL-01C5's Avatar
MDL-01C5
Default Re: Problems with my HID's ... (EHS)
How did I know that I'd see you here :lol: :D :p: ;)
Old Aug 9, 2001 | 01:50 AM
Lashtal's Avatar
Lashtal
So, how do you like your HID's?
What gain over stock or the Euro version head-lights do you see on them?
Curious - as I am thinking about getting a set!
Old Aug 9, 2001 | 09:54 AM
Innocent Bystander's Avatar
Innocent Bystander
I agree with goin' after the grounds. The grounds for the Left Low beam is on the left and rail underhood and the right ground on the right rail.b
Old Aug 9, 2001 | 01:47 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Default Re: Problems with my HID's ... (Innocent Bystander)
MDL-01C5,
I am sorry to hear that you are having problems with them. So far, almost all HID kits out there on C5's are working fine. You have a 5 year warranty on the bulbs AND the ballasts.
If you want, we will replace both of them to you at no cost.
Just let us know and we will have them replaced immediately.
We want you to be able to see great at night with no problems.
Shawn
Old Aug 9, 2001 | 09:49 PM
MDL-01C5's Avatar
MDL-01C5
Default Re: Problems with my HID's ... (L.A. Performance Division)
Notice to all forum members----
OUTSTANDING CUSTOMER SERVICE IS ALIVE AND KICKING!!!:D
Thanks to LAPD for the proof!!
If I can't fix them myself, I'd be happy to take you up on your offer :cheers:
Old Aug 9, 2001 | 10:32 PM
EHS's Avatar
EHS
:confused: :confused: :confused:
Old Aug 10, 2001 | 06:11 AM
MDL-01C5's Avatar
MDL-01C5
:rolleyes: :p:
Old Aug 10, 2001 | 08:56 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
The warranty on the H.I.D.'s cant be beat!!! I dont care if you like the system, hate the system, or think you know all about the system!! :troll
The main thing here is... We have a 5 year warranty and they stand behind the product!! :cheers: Makes me feel good that I purchase quality parts!! :cool: Thanks Shawn!! :cheers: :smash: :smash:
vetterdstr :seeya
Old Aug 10, 2001 | 01:27 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Default Re: Problems with my HID's ... (vetterdstr)
Guys,
You are very welcome. We don't want to see any of you frustrated or hassling with something that can be easily replaced, especially when it comes with a warranty that surpasses the C5's GM factory warranty.
If you purchase a product from us that is not working properly or is defective, WE WILL REPLACE IT!!!
Our goal is to make you happy and nothing is more important than that!
After all, it is only money.
:D
Shawn
Old Aug 13, 2001 | 05:30 PM
EHS's Avatar
EHS
:rolleyes: :p:
Matthew:
So, any news? I know Shawn at LAPD is terrific and will definitely honor the warranty, but did you have to go through the PITA to return them or were you able to jury rig the system and get it to work for now?
If you did need to return them, did you try substituting an 80w/80w H4 bulb -- that's probably a lot easier than having to change out the entire assembly and going back to stock so that you have use of the car.
I feel your pain -- Hope you are able to resolve the problems and get back on the road. I can only imagine what it must be like not to be able to drive your car because of a simple electrical problem.
Old Aug 14, 2001 | 02:37 AM
c5vett's Avatar
c5vett
So, if you are running the T-84 housings that only have provisions for a single bulb (right) and HID has no high beam, then is it correct that you have no high-beam?
I know most of the HID cars I've driven, the light works so well you don't use your high beams anyways, but I was just curious...
Thanks!
Old Aug 14, 2001 | 09:44 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: Problems with my HID's ... (c5vett)
Let us know if your able to correct the problem on your own and what the cause was if it can be determined. Good luck.
Old Aug 15, 2001 | 11:12 PM
EHS's Avatar
EHS
That's correct.
To Problems with my HID's ...
