Serpentine belt is chirping again!
Old Feb 8, 2006 | 02:18 PM
yzfrr1's Avatar
yzfrr1
Default Serpentine belt is chirping again!
The dealer installed a new belt 6 months ago and this cured the chirp for about 4 months. Has anyone has a similar problem? Thanks!
Old Feb 8, 2006 | 02:52 PM
TeeJay's Avatar
TeeJay
There are a couple of tensioners that can help the belt talk. Any coolant loss? Is the condition unique to any particular condition or circumstance?
Old Feb 8, 2006 | 03:57 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
My 5.3L Trailblazer has gone through 3 belts in 2years, chewed right through. One of the pullies keeps coming lose, so start there.
Old Feb 8, 2006 | 07:24 PM
LoneStarFRC's Avatar
LoneStarFRC
Like Rich said, check your pulleys and make sure they are running fairly true and not chewing on the belts. Also check to make sure the grooves are clean. Use a wire brush in the grooves if necessary. Sand, dirt and other debris can (and does) collect in the grooves over time and can cause the belt to ride higher in the grooves than normal too. HTH
Robert
Old Feb 10, 2006 | 07:05 AM
cuspid's Avatar
cuspid
Someone said scrape a bar of soap on the underside of the belt would quite it up. I know it works great on zippers and screws going into wood.
Old Feb 10, 2006 | 07:09 AM
Rhode Warrior's Avatar
Rhode Warrior
That's just a temporary cure. Try the Goodyear Gatorback belts from Autozone. Lots of people here have posted great things about them. I just completed a H/C install with UD pulley so I have new Gates belts and they only took a week and a half to start squeaking. I just bought a couple of Gatorback belts but haven't installed them yet. I will post the results when I do.
Old Feb 10, 2006 | 12:46 PM
screw991le's Avatar
screw991le
Please do
Old Feb 10, 2006 | 03:54 PM
kdub1's Avatar
kdub1
Definitely get the Goodyear belts. My friend has an automtive shop and I've seen them cure MANY squealing problems. They just don't squeal where others do. Can't say why, but he swears by them.
Old Feb 10, 2006 | 05:27 PM
breaking72's Avatar
breaking72
Cruising
I know when my belt was chirping they said it was sopmething called the Harmonic Balancer.....the chirping was unbearable. Prior to it being diagnosed with the above I had tried a belt dressing which made matters worse and eventually I had Chevy replace the belt. The chirp was still there but faint and they then put on some more belt dressing. The chirping got worse until I cleaned my engine, wiped off all that remained of any dressing and replaced the belt again and the chirping totally stopped. Thank Goodness, because to replace the harmonic balancer was over $800.00.
To Serpentine belt is chirping again!
